AMDanBailer
AmericanMuscle.com
I'm trying something different for the forum specials this month. There's a 13% discount on selected parts I've seen requested around the forums and a different mix of parts. This is such a steep discount, we can't apply it to every item in a category, but part numbers that qualify are listed here for you. Deals are good from December 1st through December 31st, 2010 for online purchases made at AmericanMuscle.com. Enter the coupon code at checkout to receive these special prices. PM me with any questions, suggestions, or feedback.
13% off Selected Subframe Connectors
Stiffen your chassis up so you can launch off the line without fear. You'll save your frame and improve your drag times.
Discount good on items: 94335, 56527, 47001, 47023.
Discount Code: fcdec13subfc
http://www.americanmuscle.com/mustang-subframe-connectors-connector.html
13% off Selected Cams & Accessories
Cams are an essential mod once you're past basic bolt-ons. Upgrade your stock setup to squeeze the most power possible out of your engine.
Discount good on items: 30100, 30101, 30102, 30103, 30104, 30105, 30106, 30107, 30121, 30122, 30123, 30124, 30125, 30126, 30127, 30128, 30129, 68002.
Discount code: fcdec13camsnac
http://www.americanmuscle.com/mustang-camshafts.html
13% Off Selected Differentials & Accessories
Your stock rear end lets you down time and again, so it's time to switch to an LSD so you can make the most of the power your engine's putting out.
Discount code good on: 24062, 50090, 50092.
Discount Code: fcdec13diff
http://www.americanmuscle.com/lsd.html
13% Off Selected Anti-Roll Kits
Reduce body roll and increase handling with an anti-roll kit. You'll take those corners better, and enjoy driving more.
Discount code good on items: 47700, 47701, 47702, 47703.
Discount Code: fcdec13antiroll
http://www.americanmuscle.com/mustang-sway-bars.html
Important Legal Stuff: Forum Coupon Code Discounts only available for online purchases at AmericanMuscle.com. All prices subject to change. All sales and sale pricing subject to availability. All prices are good only while supplies last. Only one coupon code can be applied per order. Coupon prices are only valid when coupon code is entered during the checkout process. Reduced prices will be seen during the checkout process after a coupon code is entered. Thank you for reading all of our tiny legal text.
