Shifter arm question
Sharad
Site Sponsor
Fort Myers, Florida
Hurst usually uses standard thread on their shifter knobs while the factors and most aftermarket shifters use metric thread. Our trick stick handle uses the metric thread, so if your Hurst knob is standard thread, it won't fit.
A quick way to test is this: if your factory shift knob will work on the hurst shifter handle, then it is metric thread and you can use the Hurst knob on our handle. If the factory knob will NOT thread onto your hurst handle, then you can't use the hurst knob on our handle.
Make sense?
IHVOCD
Im pretty sure the factory knob wont work on my hurst handle.
Sharad
Site Sponsor
Fort Myers, Florida
Well, the good thing is that since our handle has the factory thread, you can look at any shifter knob (not Hurst) and it should fit!
IHVOCD
Whats the difference between the extreme ultralite and the ultralite shifter arm?
