SHR Tru-Billet Fuel Door - Machined Aluminum
foolio2k4
Buena Park, CA
Selling a used SHR Tru-Billet Fuel Door. It is machined aluminum with the GT logo.
Its in great condition with no major scratches or anything.
Retail price on this is $120. Letting this go for $75 shipped.
Looks great on any stang!
The SilverHorse Racing Tru-Billet doors were the first and only ones on the market made from over 5 Lbs. of solid 6061-T6 certified aluminum billets, machined down to an exact fit instead of being bent or cast into shape.
from SHR:
This results in a part that is lighter than the stock fuel door it replaces (approx. 1 Lb.), yet will take just about whatever abuse you want to throw at it. After anodizing or plating, they are hand-assembled using stainless steel hardware, precision ground stainless hinge spacer/washers, and nylon mounting bushings for a perfect, no-drill fit. Retention and closing of the door is accomplished with cadmium-plated press-fit neodymium magnets and an exclusive striker plate that is retained by stainless steel hardware, not loose-fitting glued-in components. Installs in about ten minutes using common hand tools, and they are available in different engraving options and in a variety of finishes.
