sold
Status
Not open for further replies.
LRS197
Little Rock
SOLD
This is a Schroth 4 point seat belt harness that bolts into a S197 mustang. I purchased this new in May, 2015. The belts on the outboard side bolt into the factory seat belt anchors and the inboard side uses the factory harness to connect. Easy to install and remove. All is in good condition
$125. Nope. Now $100 plus shipping from 72002.
LRS197
Little Rock
Price drop to $125. You can leave the factory belts installed and use those and leave the 4 point harness installed at the same time. Pick which one you want to use, factory or the 4 point harness.
LRS197
Little Rock
Yes the inboard side uses the factory female belts. On the outboard side you install new male connectors at the base of the front seat and on the outboard of the back seat while leaving the factory mounts in place. That way you can either leave the 4 point in place and use it or disconnect the front seat part of the 4 pt and use the factory belt. You can also remove the 4 pt belt easily. I used this 4 pt belt with corbeau seats which are still in the car.
drj2k1
I'll take it. check the message on your profile for my email
Thanks,
Jon
Status
