some questions...
3vs197
so some of you may know i broke a valve and am in the process of getting new heads and having some work done on them. im kind of set on getting stainless valves and a 3 angle valve job. but i can't seem to find any pricing on valves. also as far as tensioners go, is it worth it to get the 2 valve iron tensioners instead of the stock plastic ones i have now? and lastly how much can i safely mill the heads to raise compression?
thanks.
