rzaenglein
I have a 05 GT making 375rwhp. Car has big issues with very fast shifts. primarily going into second and a real big issue with 4th. 3rd hardly ever gives an issue. Under normal driving car has no issues except when the car is first started. When the tranny is cold the first few shifts into 2nd and 3rd have to be very slow or it will give a slight grind. It also feels when i pump my pedal a little bit it stiffens up a bit.
The drivetrain setup is a TR6060 with a mgw shifter, spec stage 2+ with aluminum flywheel and pressure plate, new factory slave cylinder, new master cylinder, ford racing clutch line.
The transmission is a level 6 done by rpm transmissions out of muncie indiana with maybe 2000 miles on it. I noticed when I put the car in first with the clutch to the floor when i revved it to 5500 and above it made the car move.
I know the clutch not completely releasing is at least some of my issue if not all of it. I think there is air in the system that I cannot get out. I have pumped the pedal for ever and vacuum bled it numerous times. It holds good vacuum.
Has anyone out there ever taped into there slave and threaded a bleeder valve into it? Is there any aftermarket slave that has a bleeder? Anyone had to shim there slave? Any other ideas???
