Shane361
About to install and curious if it's as simple as it looks. Any tricks of the trade I need to know? Does the car need to be off the ground and no pressure on the wheels? Thanks in advance.-Shane
Why wouldn't you measure to see how far the stock bar is off and adjust the new bar on the bench then install it voila
This would work great, you would just have to put the ole foot on the body and push it over.
You can generally get close, by "bench setting" it.....however....it is not truly aligned until you verify by measuring/adjusting once it is on the car.
There are many ways to install it. Some are easier and better than others, depending on the person doing it. I suggest putting the car in the air, and tackling it the best way you see fit.
Loosen up both jam nuts and rotate the bar. Each of the rod ends rotates in opposite direction so the panhard bar is made longer or shorter as you rotate the bar to move the axle from side-to-side.
Everything he said !!!!!I also installed mine on ramps without taking the wheels off. The only catch for me is to use a Craftman standard open end wrench to tighten the jam nut inside the boxed area. All of my combination wrench (box/open) are too big to fit in there.
I guess I could have removed it from the car to make adjustment, but that was too much work.
Don't forget the blue loctite on the jam nut...
