Liftedbronco
Shredder
So it was fine after I had gi joes 8 rib setup and tensioner. Then after about 3 days a new squeak started. Its not as high pitched as the belt squeal i was getting. Its more of a rub sound. Checked and nothings rubbing though. Its definitley coming from the tensioner. And theres alot of belt dust behind it.
It looks to me like the back side of the belt is getting chewed up. It looks like it might be rubbing against the inside (motor side) of the tensioner pulley shoulder.
Also, what are you all using to undo the lock nut on the tensioner bolt? Its hard to get in there.
