Stock shifter 05-10
ctt326
Brenspeed Hater
Fort Wayne, IN
I broke a piece on the stock shifter so I need one asap.
EDIT: I actually need the linkage that connects the shifter to the transmission.
ctt326
Brenspeed Hater
Fort Wayne, IN
The stud that bolts the linkage arm to the actual shifter part on the transmission.
You mean the bolt that connects the arm to the trans more specifically the part where the gears are
Newman
sumidicsayhuh?
Houston
Got one with a small STS
fdjizm
Drag Queen
NY/NJ
Someone should have it, but the issue is you still need that piece when you change a shifter and aftermarket shifters don't come with it.
