Used 05-10 3v OEM Phasers and Chain Guides
Samos3
St. Louis
Okay, so I need a pair of stock, oem cam phasers and chain guides for an 05-10 3v. I'm not going to run them. I have a partial motor, seemingly a good block, that came from a car that took a good frontal impact. Cam covers and timing cover are pretty busted up. Phasers and guides are broken, as well. Even the heads have some of the timing cover mounting ears broken off.
Anyway, what I want to do is get a pair of oem phasers and guides so I can reassemble enough of it to practice replacement of the timing chain, phaser, lash adjuster, etc.
My car currently has 225k plus on it and could probably use some new parts and preventative maintenance. With this other motor, itself intended to provide a core block/crank for a potential replacement at some future point, I can practice before tearing into my daily driver.
Anybody have some well used but intact parts for cheap?
