Used 05-10 3v OEM Phasers and Chain Guides
Samos3
St. Louis
Okay, so I need a pair of stock, oem cam phasers and chain guides for an 05-10 3v. I'm not going to run them. I have a partial motor, seemingly a good block, that came from a car that took a good frontal impact. Cam covers and timing cover are pretty busted up. Phasers and guides are broken, as well. Even the heads have some of the timing cover mounting ears broken off.
Anyway, what I want to do is get a pair of oem phasers and guides so I can reassemble enough of it to practice replacement of the timing chain, phaser, lash adjuster, etc.
My car currently has 225k plus on it and could probably use some new parts and preventative maintenance. With this other motor, itself intended to provide a core block/crank for a potential replacement at some future point, I can practice before tearing into my daily driver.
Anybody have some well used but intact parts for cheap?
Dino Dino Bambino
I have a red car
Cyprus
Hello mr how are you? few weeks ago a man spoke about this Used 05-10 3v OEM Phasers and Chain Guides and he said it in a good shape, his yet to send pics of it, he also state he will be selling at a good rate. i advice you contact him at buyingandsellin793 at aol dot com,so he can send few pics of it his andrew by name tell him james referred you.
Bullshit! You've copied/pasted the same message on the last five WTB threads. Do you really think anyone here is stupid enough to fall for your scam?
Samos3
St. Louis
Picked up most of what I need. Still need a pair of intact, oem phasers. Nothing modified, just old originals to play with. Must have undamaged pins for the cams.
Samos3
St. Louis
I do. Like I said in my original post, I'm not installing them on a motor to be used, so oem, intact and cheap is what I need.
