With the best prices around on Vortech / Paxton tuner and complete kits, we have put together a winning combo we like to call our "Beefcake Special"
If you want your car to run at it's peak you need the best. The best injectors are the Injector Dynamics. The #1 Tuner out there is Lund Racing! And of course you need a great supercharger which can be had with Vortech / Paxton!
So,
Our Beefcake Special Includes
Vortech V3 or Paxton 2200 Tuner Kit
Vortech 2011-13 Boost referenced BAP
ID 1000 Injectors
Custom Lund Remote Tuning Session
2nd S/C Pulley of your Choice
Right now, if you purchase the "Beefcake Special" combo. We will throw in the the ID 1000's free! That saves you $960!!!!
$5799 to your door.
Give us a shout!
513-478-1965
This combo should give you everything to make 700+ rwhp on your coyote!
Plenty of options here as well to delete / add items to the special such as Vortech / Paxton or JLT CAI's, Optional Boost a pumps, etc...
The Competition Kit, if you want to go a little further gives you the Paxton 2200 Oil Fed or the JT Trim Oil Fed, which is what I have been 9.27 on at over 3850 lbs @ 18 psi, and 9.4's @ 16 psi.
The competition kit includes either oil fed unit, JT or 2200 along with 8 rib upgrade and vortech / paxton competition inlet / vortech boost a pump
With the custom Lund Remote Tune, and ID 1000 injectors, would be $6249 for the special!
The YSI Upgrade would be $6449 on the special!
The YSI will definitely spin higher, but your going to sacrifice alot down low, and to really take advantage, your going to need to get into carbonite pulleys / overdrive balancers, etc..
I can also break the kit up as need be too
Happy to put custom kits together for items you want / don't want!!!!
don't have a coyote! call for specials on other years!
So,
ID 1000 Injectors
$5799 to your door.
Give us a shout!
513-478-1965
