Sayonara transmission!
hmmm cryo treated 6060....???
CLUTCH - in his case...
Spec P-trim twin disc....???
I seriously doubt that it's going to run sub 10.00 (or sub 6.40)... but I have to admit it would be a pleasant surprise if it did.Don't forget the full cage you are now going to need for that monster...
Well, if there are 6.3s in it, then I think I'll be OK at the tracks I run at.It wouldn't surprise me at all if you break 6.40 in the 1/8 - in fact, I'd just about lay odds you will.
I think you may eventually 'upgrade' your blower - and then it's for sure - but I still think you can see a 6.3x on the new set-up when it's all said and done and dialed in.
What better reason to get booted from a 1/4-mi track than running under 10.00!Yeah - but the problem is will YOU!...lol
Meaning if you turn 6.3's - you know you are going to take it to the 1/4 to see what it will net. No denying that - it's fate...
drive shaft loop??? neede anyways what rims are you running and did you need to grind your rear brakes?
