Tire and Rim question..
06GTMustang89
Corner Carver
Cary Area, NC
26x11.5 on 15.8 or 15x10?
Im pickin up some 26x11.5 R15 ET Streets tomorrow only have 5 passes on them and the pair is 200 bucks can't beat it..
So my question is do i get 15x10 or 15x8?
15 x 10
you'll need to re-locate the sway bar and put longer studs on the rear axles as well if your using a spacer (which almost certainly you will have too)
the sticky says i won't need the longer studs or a spacer..just to relocate the swaybar..
pretty sure you need both. Unless your buying Holeshots, those dont need longer studs and come with spacers.
would a 15x9 with 5.5 backspacing work?
IDK, I'd think they would stick out of the wheel well some depending on the BS
06GTMustang89
Corner Carver
Cary Area, NC
the 15x8 summits with 5.5" backspacing working for our car no problem....the sticky even says that...
My question was with the tires on the wheel...which that picture confirms they do fit on the 15x8 fine...
