tire wear
datmbn
Sweden city Motala
The question is which tire pressure do you have to make the tires wear evenly?
I bought new tires this spring which has now rolled about 10000 km (235x50x18 originals)
The rear tire is barely worn at all, while the front tire has about 2/3 left and is noticeably more worn on both
inner and outer edges. The tires are evenly worn so I do not think there are any problems with the wheel alignment.
I know it says that you should have 2.3 bars so I had it from the beginning, but as soon as I noticed it was uneven
I increased it to 2.5 rear and 2.7 front, but it does not seem to make any difference.
regards Mats
alignment. Needs slightly more toe in. This will also make the car more stable and less twitchy at speed.
As Skwerl suggested - wear on the edges typically indicates alignment issues
datmbn
Sweden city Motala
If you look at the wheels how they are angled, then I wonder if it may not be that I have the right aligment, but with most city drive (low speed sharp turns)
I scrub the inside of the outer tire and the outside of the inner tire and vice versa
I start to think if it's not the way it will be (many..... small roundabouts in town now + a 180 degree right turn into the parking lot at work)
The winter tire that is narrower 115x60x17 does not have the same tendency
Our other car a Citroen C6 also has the same tendency to wear more on the edges.
datmbn
Sweden city Motala
I just find this
"Tire Experts" in Sweden recomend, from the vehicle's specified factory data:
Summer tires in normal profile an increase of approx. 10%.
Summer tire in low profile an increase of approx. 15% (high speeds about 20%)
Winter tires Nordic spike Free, an increase of approx. 20%.
86GT351
Sunny South Florida
If you can visually see an Alignment angle that is off, you have an alignment issue. Have the car put on a machine and at least check the readings. Alignment is a huge contributor to tire wear. Also edge wear on both edges can be caused by too low of a tire pressure. raise all the tires 1 pound and see what happens. Higher air pressure theoretically reduces the contact point of the tires slightly.
