1. So is the 75w-90 the correct oil no matter what brand??? 2. Exactly how much goes back in???
Also, just to be clear ... this is the Redline fluid in question, correct?
http://www.redlineoil.com/product.aspx?pid=45&pcid=7
That has a much lower cSt@100c (10.6) than the MTG, and they have other products with a much closer rating, such as the MT-85 75W85 (12.0) and the MT-90 75W90 (15.6).
Yes, that's Red Line MTL we have been discussing. It will also work well in your MT-82. This is my motto, "as thin as possible, as thick as necessary".
With that being said...that means I want a fluid that allows for great shifting, but is also thick enough to provide a good cushion for metal to metal contact, while minimizing gear noise. That's why I choose Amsoil MTG.
Thanks for the advice! I just was unsure about how thick was "necessary."
From what I have read, the German designed, Chinese built Getrag MT-82 is an older style "noise inherent" design. Ford's idea was to use a more viscous fluid to combat gear rollover noise, but chose a cheap petroleum based lubricant. The transmission became grind city in colder climates.
I'm pretty sure the early build 2011 cars were filled with Ford's full synthetic gear oil. At least that is what the TSB says concerning the fluid swap.
You do realize that the term "synthetic" in the US is used loosely. It's OK to call refined petroleum a "synthetic" in the US. No where else in the world is this tolerated.
group III base stocks are hydrocracked "highly refined petroleum" and I don't care what the big oil companies try to make you believe, it's inferior to true group IV (PAO) and V (ester) base stocks.
I understand what you are saying. Just out of curiosity do any new car makers use group IV or group V based fluids in their tranny's?
ok so heres my dilemma, my car has a whine in 1st through 3rd. i only have 950 miles on it
other than that it shifts ok, i wouldn't call it fine, but i wouldn't call it bad. i thought my 03 tacoma with 100k miles shifted shitty, but after driving my mustang it feels like butter lol.
anyways, should i try some different fluid or take it to the dealer first?
i'm worried that it might be a cracked input bearing race or something serious, i don't want to mask the problem then have it rear its head after the warranty is up
