ChuckyRick
So i was doing some pre-dyno maintenance in preparation for a tune session and i might have run into a little issue. It came up after i cleaned my TB. i'm some glad i did because there was quite the buildup of sludge behind the blades. Basically i have a problem with hanging revs between gears. Nothing extreme, but it seems when i hit the clutch and leave it depressed it hangs at that rpm for around a full second and the come down is quite slow compared to pre-TB Clean. Again nothing super serious like 30 seconds to drop 1000rpm for example. But if i press the clutch at lets say 4000rpm, and after the approx 1 sec of hang, revs drop at a very linear rate of probably 1000rpm per 3/4 second, and it only drops down to about 1000rpm, instead of dropping to idle. Compared to before it would just drop right down to idle within a second, no hang time, nothing. The part i don't fully understand is if i'm sitting in the driveway in neutral, or in gear and clutch depressed- revs drop just like before, right down to idle. Problem only occurs when i'm moving. Now from what i can understand (but i could be wrong) it can't be a TB issue because it would happen all the time whether i was moving or in gear or not. Also i don't think it's any sort of clutch issue because a) there was absolutely NO sign of this before i cleaned the TB, and b) there's no slip at any point. Car isn't throwing any unusual codes, i have 2 codes for slow response 02 sensors or something along those lines, which i'm assuming are just flagging the downstream O2's because i have longtubes installed and no tune as of yet to override them. So really my main question is could this simply be a tune (stock tune) issue? And perhaps i never noticed it before due to my TB being so dirty? should probably mention it was dirty enough to cause the car to idle slightly low, which i thought was just due to having some parts installed and not being tuned accordingly. I installed my heat shield for my intake to cut down on set-up time whenever i come down to the shop, and in order for my stock intake to fit i had to cut off the bottom part of the airbox so that it's just open filter, but i can't see this making a difference as 99% of aftermarket intakes are open element anyways? I searched all the mustang forums and a few people did mention that hanging revs were a tune issue for them,but most of them were running a mail-order tune not stock tune. They just got a revised tune and fixed their issue. Also nobody seemed to have an issue like mine, Hence why i'm making this post. I have no idea what my problem is, i'm just hoping it's a tune issue and nothing that will cause an issue come time to get the car on the rollers. Just wanted to explain my situation to you guys and see if you had any ideas on what it could be. I must say the car is extremely drivable, just i'm not used to the car ever behaving this way. Plugs & Coils were new a month ago (Ford Racing & MSD respectively), fuel filter (oem) was changed only a week ago as was the oil (ford synthetic & oem filter) So all i can come up with is thinking it's a tune issue, but obviously a ford tech here or someone that tunes these would know alot more about that than me. Thanks guys, i'm REALLY hoping someone can help me out here
Note: I don't fully remember what i have wrote down in my sig, and i'm not sure how to change it on mobile. So i'll mention it's a '05 Mustang GT and the only mods i have installed right now are pacesetter LT's, corresponding H-pipe, MBRP axlebacks, UDP's, MSD Coils & a drop-in K&N filter in my (hacked up now) stock airbox, if you consider that a mod. Alot more sitting in a box in my garage but have to wait for dyno day to install!
