water coming from passenger dash area
Allen
Knoxville, TN
We had A LOT of rain last night and I suddenly had water coming from under my dash this morning on the driver side. Whenever I would turn a corner or go up a hill it seemed it would come out more. I looked under the dash when I got to work and it seemed to be coming from a plastic thing behind the glove compartment. Any ideas?
irishpwr46
Official Site Vandal
NYC
use the search feature, it has been covered a few times
these should help
http://s197forum.com/forum/showthread.php?t=61&highlight=passenger+side+water
http://s197forum.com/forum/showthread.php?t=63604&highlight=water+leak%5C
http://www.s197forum.com/forum/showthread.php?t=31562&highlight=TSB+07-14-6
http://s197forum.com/forum/showthread.php?t=31562&highlight=water+leak\
bville racer
I had that same problem with my 69 fastback, for me it what the heater coil that runs behind the glovebox that was leaking coolent inside of the car. Dont know if ford still has that same kind of setup today but its worth a look. To start at least. Good luck
merlinv
Fast little blue pony
Sunny Ft. Lauderdale
your drains are clogged up, you should see a flat rubber tube on both the right Passenger right below the battery and onthe other end (driver side near the center behind the engine) squeeze it and you find a lot of crudd in them the water is comming in from your cabin filter, water level is not draining so level builds up until it works it's way through the cabin filter, If you have the time remove the plastic pane under the hood and replace your cabin filter it will smell bad and get mildew there...
Sal
keeno
Mustang Freak
Atlanta, GA
You are lucky if it isnt coming out on the passenger side..better take care of those drains before water gets on your smart junction box behind the passenger side kick panel. Electrical nightmare if that starts shorting out!
Ken04
gm troll basher
Santa Rosa Ca.
one of these things is incorrect, which one ?
merlinv
There's only one way for it to enter the car... through the cabin filter which is on the passenger side under the hood pan.(plastic piece)... as the water level rises it seaps through the paper/fiber filter and into the evap system and if you get a large amount of water build up it will almost transfer over to the driver side as you turn and brake... It's happened to me...I know we had three days of continuous rain and I had almost six inches of water inside the car floor..
Allen
Knoxville, TN
Sal
Thanks this was it! I replaced the filter too. Both drains were packed full of dirt. Cleaned them out good and put them back in. Hasnt been a problem since. :thumb::thanks1:
