The full Roush phase three package already has a boost a pump.
First and foremost I would encourage you to dump the ROUSH tune and purchase a tune from VMP. The difference in that alone will be amazing. I learned this first hand with a phase one package. I turned my back on Roush from that point forward and referred all future upgrades to VMP Performance and have never regretted it. What I do regret is not having the VMP supercharger head unit over the inferior Roush head unit.
As mentioned VMP will give you good direction. They won't short change you or treat you like a second rate customer as was my experience with Roush engineering when I tried to resolve issues being caused by Roush's nanny strategy tune.
For reference I am running an 82mm with 47lb injectors with a VMP boost a pump, JLT 123 intake, and dual 60mm TB on my Roush head unit with the rev limit set at 7700 RPM. Everything is fine at that level. I was considering dropping to a 79mm pulley and was told I could do this without updating anything but that they would have to restrict the rev limiter to a lower setting. Based on that I considered that half doing it, so 56lb fuel injectors along with the 79mm and retune are the potential direction this year after the stall converter goes it if my goal is not achieved at the current power level.
Best of luck.
