Why did Ford decide to do this? It's obviously more work and money for them to engineer a two-piece shaft, and it's clearly heavier than any one-piece. So why did they do it? Did they find vibration issues with one-piece shafts?
They noted "cabin noise" in the press release...Why did Ford decide to do this? It's obviously more work and money for them to engineer a two-piece shaft, and it's clearly heavier than any one-piece. So why did they do it? Did they find vibration issues with one-piece shafts?
Driveshaft definitely contributes to this and yes it gets noticeably better with a 1pc...I experience a lot of 'clunking' at low speeds/low gear (i.e. the car doesn't roll smoothly). Is that a driveshaft thing...or an engine/tune issue?
Hey if you want to catch up with me some time this week I'll take you for a ride and let you feel it for your self.That leads me to my next question...
I've heard people say the addition of a one-piece shaft makes the car feel smoother...
They have been destroyed by high HP setups... I have read of 2 instances of failure in stock form which appeared to have been seized pinions from the factory - but no they are not "prone to failure" from what I have seen (JMO)Have there been any OEM driveshaft failures? I would like to replace mine down the line, but since I don't do any type of racing it's not really a priority of mine.
It'll reduce it, but not eliminate it...and since the Spyder is lighter, and requires less to move it, if you drive like a dork with sharp throttle imputs (on or off), it will still "slap". But like I posted in a separate thread, slap is life in the fast lane: my '99 C5 Vette did it, and it had the DS inside a torque tube..my '97 Viper GTS did it, and (sigh) my S197 does it too...smooth throttle input will all but eliminate it...but b, c, and d are all valid reasons.Since I really don't apply to or need options b., c., or d., option a. is why I dislike the stock driveshaft. It's tough to shift smoothly when I'm loping around, shifting at < 2,000 RPM.
