I have 2 for sale....$399 each shipped NEW!
The Wide Band Commander provides a complete picture for proper air-to-fuel ratio analysis. This unit has the capability to read from 10.0:1 to 18.0:1 using a bosch 5 wire LSU4 Wide Band Sensor. Wiring harness includes output ports and input ports for, nitrous, water injection, timing retard, recording boost, etc.... This is the most complete kit available on the market today. I have 2 for sale. They are both new in original packaging, never opened. Both are Black face with silver bezel.
Once installed, the Wide Band Commander provides an “in-vehicle” dash mount AFR display gauge with a built in warning light, as well as data recording which can be retrieved and analyzed using the supplied software package.
Features:
- Lowest cost / most complete kit on the market! 1 wire tach hook up on any vehicle, no need for a tach adaptor
- Modular programmable output for nitrous, water injection, timing retard, etc......endless possibilities
- Record files with or without a laptop
- Play back log files with the WBC software or export a text file
- Uses highly accurate, readily available plug and play Bosch LSU4 wide band sensor
- Helps you achieve maximum SAFE power
- Download software and firmware updates 24/7 from widebandcommander.com
- Dynojet quality & toll free technical support
Features:
