GT550-S197 Coyote Stage III Supercharger Kit
Department Of Boost
Alpha Geek
Department Of Boost
GT550-S197 Stage III
Supercharger Kit
For 2011-2014 Coyote Mustangs​
(Pictured with optional composite heat barrier)
>>>>Before You Go Any Further<<<<
Make 500-650 Rear Wheel Horsepower Using The Supplied Stock 2007-2012 GT500 Blower
You Can Make 500-850 Rear Wheel Horsepower Upgrading To A Stock 2013+2014 GT500 Blower In The Future
You Can Make 550-1400 Rear Wheel Horsepower Upgrading To A Big Aftermarket GT500 Blower In The Future
The coolest running positive displacement supercharger system available. Which means you get more of your power, more of the time. 550hp with this kit is more HP than any other kit making 550hp
Using the Department Of Boost GT550-S197 Stage III Supercharger Kit You Can Make “All The Power” For Far Less Money!
And in the future it is fully upgradeable To REDICULIOUS Horsepower levels!
Features and Specifications:
-Complete installation can be done for as little as $3900
-Biggest/best flowing/ best cooling intercooler in the industry…..PERIOD!
-Optional composite insulator available for EVEN LOWER intake air temps
-Tested and proven
-Best horsepower/ dollar ratio of any modification available for the Coyote
-Uses OEM GT500 Roots Improved or TVS blower for cool running and bulletproof reliability
-Or can be used with BIG screw blowers for insane levels of power
-OEM drivability
-Complete installation instructions available
-Optional boost levels
-Uses mostly OEM parts for unrivaled reliability and parts availability
-As easy or easier to install than the other blower kits available for the 2011-2014 Mustang GT
-NO fabrication necessary
-Billet construction
-O-ring sealing. No messy sealants/RTV’s
-Easy intercooler fitting/port access
Intake Air Temperatures:
If you are new to forced induction you probably don’t understand the overwhelming factor that is intake air temperatures (IAT’s). This is a very complex subject, because this is an advertisement page and not a tech article we will keep it to the basics.
When air is compressed (that’s what forced induction is), it heats up. Hot air is bad for two reasons. One, hot air is not as dense as cold air so hot air makes less power. Two, hot air is more likely to cause detonation (knock) and engine damage. To prevent this engine damage the cars computer (ECU) monitors the IAT’s and as they go up the ECU pulls back ignition timing to keep it safe. The problem is that less timing equals less power. So when you have higher IAT’s than you want you are losing power because the air is not as dense and losing power because the ECU is pulling ignition timing. How much power do you lose you ask? A LOT is the answer. On your normal average 80deg day driving around on the street it is more common than not for a 550hp car to be down 80-100hp. Yes, 80-100HP!
IAT’s are the dirty little secret of the forced induction industry. Almost all blower/turbo manufacturers package their systems with the bare minimum. And that bare minimum means that most of the time you are driving your car you are not making the power it did on the dyno. Keeping IAT’s down on the dyno is easy. Keeping IAT’s down when you are driving your car around isn’t. It costs a lot of time and a lot of money to solve the IAT problem. And frankly until now no one has done it. This manifold represents the first time the IAT problem has been attacked head on by anyone.
We have designed a manifold/intercooler package that is capable of removing up to four times the heat of ANY positive displacement manifold/intercooler offered by any other manufacturer.
Bottom line. When using our package if you pull up next to another Coyote Mustang with the same dyno numbers as you, yours will be faster.
The Stage III Tuner Kit Includes:
-Billet aluminum intake manifold with integral intercooler
-Billet aluminum idler pulley bracket
-Billet aluminum idler pulley spacers
-Billet aluminum fuel rail spacers
-Billet aluminum quick change snout pulley and hub
-Blower bypass relocation kit
-Fasteners required to install the manifold and supercharger
-New/Take off OEM M122 GT500 supercharger and elbow
-New/Take off OEM GT500 throttle body
-New/Take off OEM GT500 cold air intake/air filer/MAF housing
-New 52lb/hr GT500 fuel injectors
-Take off OEM GT500 heat exchanger
-New Bosch GT500 intercooler water pump
-Take off OEM GT500 degas bottle
-New S&H Performance fuel pump wire upgrade kit
-New Idler pulleys
-New Heavy duty belt tensioner
-New supercharger belt
-New gaskets/seals/o rings
-New intake air temperature sensor
-New hoses and clamps
-New wiring supplies
-Etc.
Optional Composite Heat Barrier:
We offer an industry only option. Our composite heat barrier. Our composite heat barrier is part of the manifold (that part of the manifold is aluminum if the option is not taken). The manifold bolts directly to the cylinder heads. Cylinder heads are HOT. 200-235deg. Aluminum is a fantastic conductor of heat. The problem with bolting an aluminum intake manifold to 200+deg aluminum cylinder heads is that the intake manifold quickly heats up. That hot manifold in turn heats up the air inside it, which is your intake air…….that you want to keep cool. If at all possible you want to keep your IAT’s down below 100deg. That is nearly impossible when the “box” (the manifold) you are running them through is anywhere from 180-200deg. Our composite heat barrier is just that, a heat barrier. Heat has a very hard time passing through the composite material we chose. That means far far less heat is transferred to the body of the intake manifold, which means far far less heat is transferred to the intake air charge.
That is not the only advantage though. The intercooler (all intercoolers as far as we know) are attached directly to the intake manifold. The manifold is aluminum, the intercooler is aluminum. The intercooler has cool water running through it, the manifold is hot. What ends up happening is that the intercooler uses some of its ability to extract heat to cool the body of the intake manifold. That is not the intercoolers job, its job is to cool the air coming out of the blower. If the intercooler is using its LIMITED ability to extract heat to cool the intake manifold body it’s not doing a very good of a job at what it’s supposed to be doing, and that is cooling the air coming out of the blower. Additionally if the intercooler is cooling the body of the intake manifold there will be more heat in the water. More heat in the water means that it will not do as good of a job cooling the intake air temps. In short, cooler water is better. And with the composite barrier the water in the intercooler system will always be cooler.
At $230 the optional composite heat barrier is by far the best bang for your cooling buck you will ever spend. Period. You can’t spend $230 on your intercooler system anywhere and get the same performance advantage. Not even close.
The only situation where the composite heat barrier may not pay for itself is if the car is a drag strip only car (only running for 15-20sec at a time) and running an ice chest/ice water through the intercooler.
What is needed to complete the installation?:
Not very much.
-You will need some standard shop supplies that if you don’t have you can pick up at any auto parts store.
-You will need a tuner and a tune.
-2011-early build 2012 cars Only:
The front timing/cam chain cover on 2011 and early build 2012 cars will not work with the belt system without modification. You can modify your stock one with it still on the car with a grinder/file/etc. Or you can buy an updated front cover from the dealer for about $100 and swap them out.
This is a 2011-early build 2012 front cover (below). If yours looks like this it needs to be modified or replaced. The difference between the front covers is the ribbing on the left hand side.
This is the later release front cover (below). If you have one of these you’re good to go.
Department Of Boost
Alpha Geek
Intercooler System Overview:
The intercooler system included with the Stage III kit:
The intercooler (IC) system included with the Stage III kit is an “entry level” system. The IC itself is the best in the industry, the other items in the system are on par with what you would get with any other blower kit. We have to do this because we cannot for example include $1800 in top shelf IC system components and try to sell on the same playing field as other blower kits.
System components You Receive with the GT550-S197 Stage III kit:
-Heat exchanger. You will receive a 2007-2012 OEM GT500 heat exchanger.
-Water Pump. You will receive a 2007-2012 OEM GT500 Bosch water pump. It is the same water pump used in almost every blower kit made.
-Degass bottle. You will receive a 2007-2012 OEM GT500 degas bottle.
-Hoses, clamps, electrical components.
Advanced Intercooler System “option”:
We don’t offer a “top shelf” IC system option at this point. You can create your own “top shelf” IC system using available aftermarket parts though. And because you don’t want to first pay for the components included in the Stage III and then buy upgraded replacement components we offer the Stage II.5 which is a Stage III kit without the IC system components. See the Stage II.5 kit for details.
Installation and Tech Support:
Complete installation instructions will be available.
In addition to that there is Department Of Boost staff which is effectively available through email 24/7/365. We may not be available on a Monday morning at 10am (we probably will be though). But we are checking emails all day and late into the night most days. It’s fair to say your chances of contacting us and getting an answer, the right answer, is better than your chances with any other supplier. You will never get in contact with the other suppliers on a Saturday or Sunday afternoon for example.
Tuning:
Any tuner that can tune a blown Coyote can tune this combo. Because it uses mostly OEM parts it is very simple. You can go to your local dyno and have it tuned. Or you can have it remotely tuned by Lund Racing. Remote tuning is a process where you drive the car while doing specific tests outlined by Lund Racing. You email them the data from those tests. They review the results, make tuning changes if needed and they email you back a revised tune. The process is straight forward and easy. It also saves you from having to trailer the car somewhere to get tuned and work around the dyno operators schedule. And in most cases remote tuning is less expensive. When you are done remote tuning you can take it on a dyno to see what it makes for power. But these days that isn’t 100% necessary. A lot of people, including a lot of people with very fast cars do not go to the dyno anymore. Visit Lund Racings web page for more details.
http://www.lundracing.com/
(Pictured installed on 2015 S550)
Pricing/Group Buy:
-The retail price of the GT550-S197 Stage III is $4695.
-The limited time Group Buy price for the GT550-S197 Stage III is $4395 (plus shipping).
Pricing/Group Buy/Options:
-The retail price of the optional composite heat barrier is $230.
-The limited time group buy price for the optional composite heat barrier is $200.
-The price for the GT550-S197 PITA Parts Package is $500 (Group Buy or not).
Group Buy Structure And Timeline:
Because we are still a very small company and manufacturing is incredibly expensive we can’t make a run of these kits, put them on the shelf and wait for them to sell. So a group buy it is. This gives us the opportunity to make a larger run, keep costs lower, and pass that savings on to you, the customer.
So here is how the group buy works:
-The group buy will be open for 60 days. Opening 8/21/15 and closing 11/30/15.
-During this time we will be taking $1500 deposits.
-These deposits are non refundable for any reason other than we don’t produce the kits.
-The deposits have to be paid with a check, money order, cashiers check or bank to bank transfer. We can’t accept PayPal because according to PayPal we have to deliver orders within 21 days of payment. We got “busted” on this and they have been watching us like a hawk ever since. We do all of our group buys using the above payment methods.
-The balance is due before your kit ships to you.
-On 10/21/15 we will close the group buy and start production. Production should take about 30 days.
-Shipping of the kits will begin on or about 1/7/16.
Bonus Round. Do You Want One For Even Less Money?!!!
If 30+ people sign up for the group buy we can knock an additional $100 off the price. This is where you the customer can help. We can’t afford to sponsor every forum or buy ads all over the place. You the customer can help us get to that 30 unit goal by advertising for us. Facebook it, Tweet it, post something about it on a forum, send smoke signals, etc. Your help can get you a lower price. How is that for a deal?!
Super Bonus Round! Do You Want A Blower Kit For Even Less Money And A Free install?!?!?!
We have only done the install of this on a (S550) 2015 Mustang. It is almost identical to the install on a S197 but we would like to do one on a S197 so we can use it to work out small details and take the opportunity to create instructions from it (pictures etc). We could use our 2012 GT for the install, but we have plenty of blown cars and we want to keep that one NA. And one of our wives drives it most of the time, and she doesn’t need or want a blower. So this can be a really good deal for someone.
Here is the deal. We would need your car for 2-3 weeks. We’re not exactly sure what we will run into when we’re doing the install so we don't want to put a real tight timeline on it. It should only take us a few days.......but, we have learned not to count our chickens an all that. We can't afford to give you a kit for free. At that point we would just use our own car. What we can do is give you an incredible deal.
$3900 for a GT550-S197 Stage III kit….. installation INCLUDED!!!
-If you have a tuner (SCT, etc) we will give it back to you tuned for an additional $250.
-If you don’t have a tuner we will give it back to you with a new nGauge Tuner and tuned for an additional $600.
-Or you can get tuning done yourself.
The above price is for your standard Stage III kit that will get you components (heat exchanger, water pump, lines, etc) on par with the other blower kits available on the market. If you want a upgraded heat exchanger, pump, lines, etc that is not a problem. We will of course have to charge more, but you will again be getting a smoking deal.
If you are interested in this offer please send us an email at [email protected].
