GCantero93
Southern California
2006 Mustang GT Coupe
Lets start at the very beginning
Bought the car a couple months ago for a steal.
Had no catalytic converters. Too loud and wanted to avoid future issues with smog, so I sourced an original catted h pipe with 34k miles on it (Car it came off of currently has 40k miles). Installed those and drove the car, but it would die on me at idle. Also, it wouldnt accelerate right away until I accelerated harder. During this time I also got a low oil pressure message once. So I ordered a new oil pressure sensor and installed it.
Then I inspected the car further and found a tear in the intake boot. Ordered a CARB approved no tune needed Roush cold air intake.
I cleaned the throttle body and installed the CAI. I drove the car and the car would bog or choke up a bit when I accelerated. Mostly during "harder" throttle. Could avoid it happening with smooth soft acceleration. The idle is a lot better now.
After some test, Bank 1 sensor 1 o2 sensor was getting stuck at 0v at times. Decided to switch out both upstream o2 sensors. After that, the problem was still there.
Did some runs and recorded live data during those runs
-STFTs (short term fuel trims) were swinging lean under load (+17%).
-LTFTs (long term fuel trims) were near 0% (not yet adapting).
-MAF readings:
Idle ~22 g/s at ~2000 rpm (reasonable).
~200 g/s at 4800–5000 rpm (reasonable for a 4.6L).
-Throttle position and commanded throttle were consistent.
-Fuel pressure relative to manifold vacuum was stable (around 260–307 kPa).
-Bank 1 O₂ sensor (passenger side) switching properly (0.1–0.8V).
-Bank 2 O₂ sensor (driver side) stuck lean (0–0.05V, sometimes creeping up slightly to .235v but mostly flat).
-DTC Code P2197: O₂ Sensor Signal Biased/Stuck Lean, Bank 2 Sensor 1.
Before I switched out the o2 sensors Bank 1 sensor 1 was giving me issues. After installing new NTK o2 sensors, Bank 2 sensor 1 is giving me the same issues now. Since it wasn't giving me issues before, I put the old o2 sensor back on Bank 2 sensor 1, but the problem remained the same.
I checked for vacuum leaks by spraying cleaner around vacuum areas and listening for changes in rpm, but that was fine.
Ran some more fuel pressure test and all that came out fine. Checked misfire counter, that was fine.
Next I checked the wiring at the o2 sensor connector
1. Heater Power: Red/Yellow → should be 12 V with key ON (was good ✅).
2. Heater Ground: Red/Blue → continuity to ground when PCM commands heater on (saw ~0.2 V pulsing ✅).
3. Sensor Signal: Gray/Red → should show ~0.45 V bias with key ON, and swing 0.1–0.9 V running (was 0 V ❌).
4. Sensor Return (Ground): Yellow/Blue → should be a solid ground reference (near 0 Ω to battery negative).
So, the PCM isn’t sending the bias voltage down the Bank 2 Sensor 1 circuit (it should always supply ~0.45 V to let it “float” when the sensor isn’t hot).
1. Broken/open signal wire between PCM and O₂ connector.
2. PCM isn’t providing bias voltage (rare, but possible if the driver inside PCM failed).
After all that testing next would be to check continuity between wiring at sensor connector and pcm. I cant seem to find a pcm pin chart or diagram anywhere.
Any insight with this issue would be super appreciated. Thank you
GCantero93
Southern California
UPDATE
Bank 2 Sensor 1 wiring:
Red/Yellow (heater power, Pin 69) → Good.
Red/Blue (heater control, Pin 29) → Good.
Yellow/Blue (signal return/ground, Pin 70) → Good.
Gray/Red (signal, Pin 10) → Came back as open with no continuity. So I tested with all 70 pins at the pcm connector and still no continuity. This is also the same wire that would read 0v during testing when it should have read .45v
Seeing as the Grey/Red wire is the issue I began looking further into the wiring loom, and behold, I finally see the cut wire. I keep looking further to find the other half and there it is, melted to the top of the transmission.
Now the only issue, is how will I repair this? There is very very little room back there. I feel like at this point, I have to have a shop replace that wire.
DieHarder
We've seen this before. That wire loom that run over the top of the transmission gets pinched/damaged more often than you'd think. Having the dealer do it is going to be expensive. Easiest/cheapest option is to ID that wire at both ends; then find spots where you can get to each side and splice in a new wire effectively bypassing the damage. Otherwise, you're probably looking at pulling the trans to get enough room to splice in a short piece of wire to repair the damage. Good news is at least you found it.
DanielAtwood
Tacoma
UPDATE
