WTB Seat Belt Presenter Arm
V8 Vol
El Jefe
Cumming, GA
Just need the driver side presenter arm as mine broke and apparently you have to buy the whole damn seat belt to replace a 50 cent piece of plastic.
Hoping someone happens to have one laying around and would be willing to sell.
V8 Vol
El Jefe
Cumming, GA
I need the arm that is holding the seat belt for the DRIVERS side. That would be sweet if you had it....let me know via PM how much and where to send the $$
This is just a pic I found on the internet
Steve@Tasca
How are you going to replace it? The seat belt passes through it, that's why Ford doesn't service it separately.
-Steve
V8 Vol
El Jefe
Cumming, GA
hmmmm, I am assuming I can separate the arm from the part that the seat belt goes through. It looks like it is possible.....but I haven't tried.
It broke from the mechanism that clicks it up and down (technical terms)
V8 Vol
El Jefe
Cumming, GA
It was very easy to remove the arm, just a single nut.....now I just need a replacement.
For now, I have given superglue a shot :2ndplace:
Imzorba
My "presenter arm" on the driver's side of my 2013 Mustang 2 door completely cracked apart today. Since I am mechanically incompetent, I used the gorilla glue idea as mentioned above, and then I wrapped black duck tape around it, after the glue had a chance to dry. Let's see how long this holds up. Very frustrating, because the plastic presenter arm piece is like a $1 piece of plastic. If I could find a replacement at a junk yard or somewhere, I don't have the skill to take apart the little mechanism that reels in the belt, so I decided to go with the gorilla glue and duck tape method. Wish me luck !
Imzorba
Imzorba
Gorilla glue and Black Duct tape did not seem to work. So now I bought a small flat, metal piece that had some pre-drilled holes in it, at Ace Hardware. I will lay it inside the broken presenter arm, after drilling holes in the 2 broken plastic sections, and try to use small screws and nuts to fasten the metal strip to hold the 2 broken plastic sections together. The presenter arm is really cheap plastic, so we will have to see if I can make this work. My mechanical skills are limited.
