New Man Cave... Garage is finally done!!
scramblr
New Braunfels, Texas
Doogie...what tires are you running? Just wondering if the hot soft compound of DRs will stick to the clear and start pulling it up. May not be a problem in WI, but maybe in TX, I don't know.
doogie
SE WI
I just started running some track day only DR's (M&H Racemasters) last fall and the couple times I pulled in, there were no issues with the epoxy. Based on how it has wore thus far, I seriously doubt even the stickiest tire would cause any issues. Especially since I top coated the floor with the Rustoleum clear as the finish seems to be very durable.
doogie
SE WI
So I might have missed this, But is that a toilet on your garage?!?!
If you are referring to the small room in the left/rear, it is an insulated compressor room. One of the several things I had designed into the house ad really helps keep the noise down when its running as I have an upright 6hp, 60 gallon sitting in there.
