Clay bar on the paint.
For the window, use very, very fine steel wool and some glass cleaner.
Window paint?
Window paint?
White shoe polish in a bottle. Comes off fairly easily if you clean it off within a day or two but it can turn semi permanent if you leave it to bake in the sun for a few weeks.
Tried clay bar on the paint. It won't budge .
I'll go at the window with a razor blade again. But the paints got me worried .
Do you have a buffer and some polish? You can buff it off.
That I do , need to bust the PC out and give it a try.
Can anyone lend me some time to do it ?
Thinner should wipe it right off.
I would try buffing it off. PC and some 205 with a polishing pad. If you dont have the materials to do that, try some duplicolor prep spray. It is clear coat safe, and will pull off any "freshish" paint off.
