My First House Mod
Dread53
Woodland Park, CO - 9000 ft!
I haven’t been doing a lot of posting lately, mostly because I’ve been a little busy. Anyone who’s seen my car knows that ‘getting carried away’ is where my projects usually start, and this is no exception.
This is a couple of before shots, and I’ve never been one for the dramatic use of color.
I’ve always been a big fan of wood, and the log cabin look in particular, so I took some of this…….
And turned it into this…..
The carpeting is temporary until I get the radiant floor heating done, then it will be cork flooring.
Here’s a couple of during shots…
The stuff I’ve designed / built from scratch include the fireplace mantle, all the switch plate / speaker / TV mounts and the indirect lighting box at the top of the wall. I can now start on the kitchen / dining room on the other side of the house, which is partially visible in the very first photo.
don_w
Dyno Numbers - Who Cares?
San Diego, CA
That looks awesome! Nice job! :thumb: And its a perfect style for Colorado.
Steps
Denver, CO
Wow...that looks MUCH better!!
Has a "warmer" feeling to it!
Very nice work!
Dread53
looks great man, Is this going to make your home more energy efficient?
The logs do have a R value of 3.5, but the bigger change will be all the leaks, holes and crap construction I'm fixing as I go. I'm also adding a 1 1/2" foam insulation between the siding and the cinder blocks, so all told I'm probably adding a R-10 or better. I found more air leaks than you can believe.
07ToRcH
Torch Red FTW
Harlingen, Texas
Is the R value of the logs 3.5 per inch or is that overall?
