S550 4 Pistons on S197 Car
NickD87
Toronto, Canada
Ed, I'm coming home from my work contract this week I think, if you get the parts in before you leave I can do the test fit for you or take it to Rick's.
I'm so excited for the potential of these.
fast Ed
Caledon, Ontario CANADA!
07TGGT
@user
Mansfield, TX
Just an FYI, base model GTs come with 18" wheels. I don't doubt most 19" wheels would clear them.
fast Ed
So everything is coming up to the dealership I'm at in Soviet Canuckistan from the Detroit warehouse. Will probably see it early next week and we can go from there.
AnotherS197GT
Serial Valve Dropper
Tampa, FL
Ed, might want to cancel your order for rotors. They are WAAAAY different. I'll post pics later.
fast Ed
Already on the way, so it will just have to go in to our return bin (only ordered one side for everything). I know the way that the venting is done is quite different than the S197.
AnotherS197GT
Tampa, FL
The offset on the rotor is majorly different. I'll be surprised if it even fits the S197 hub without smacking all kinds of stuff.
What are you guys testing pad wise? Do the S197 brembo pads fit or are you using the S550 pads?
I have S550 pads in the caliper, but I'll try a set of S197 pads. I don't think they'll work though, the S550 pads are really different.
00blkvert
Lillington, NC
Ok cool. Thanks
RedfireV8
Denham Springs, LA
You wouldn't mind posting pics for comparison and possible measurements would you? I'm most curious about the "hat height" between the two.
