SSP's 900+RWHP Turbo Streetcar
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
How hard were the clutches to do Rick?
It was really easy. I have done a lot of transmissions and Bobby has done several and its was very easy for us. Even a novice should be able to do it with some guidance. There are two snap rings that require some grunting and cussing but otherwise was easy peasy. Valvebody was easy just don't touch the electronic parts they can get screwed up or uncalibrated from static electricity like computer parts can.
There is a white clip you pull down to release the case connector to remove it before removing the valvebody.
Typical clean and inspect of planetaries and drum.
The only seals you need to really service are the front pump seals and the filter.
Gabe
Whippled Coyote
You're having BBR touch your car?
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
Like Darrin said I do the work on my car except what my buddy Bobby does since he sponsored the car and tunes it.
I bought it through BBR on Black Friday sale. They ordered it correctly this my receipt being correct. Circle D just screwed up when they built it
SMH
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
Well it was a 258mm they apparently had a batch of converters get stamped wrong in the fall of last year.
Chris has been on top of it for me and will have it done Thursday. We broke the weld on the turbine hub in the converter and ripped the rivets out of it.
Pic of what part was broke(not my actual part)
The center of this is what ripped out
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
Axles all setup now
Count those splines [emoji44]
Going to be doing some track testing Saturday at Houston Motorsports Park during a big grudge event.
Justinjor
JUIC3D
Assuming it's an 8.8, 35 spline is the biggest you're gonna get. Any bigger and the carrier strength goes byebye
TxS197
Axles all setup now
Maybe I'll swing out and come watch
Is bobby gonna be there as well.
Sent from my SAMSUNG-SM-G900A using Tapatalk
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
[emoji106]
Yes Bobby and myself are gong to be testing and tuning on Quicksilver and the Black Mamba both.
Come on out.
We are testing the new MT 29.5 10.5 15 Pro Radials on Quicksilver too.
TxS197
Come on out.
Sweet I'll have to make it out
