WOT
interesting that it fits with so little modification
If you have a dremel it's a breeze but not necessary any cutting tool will do.
what needed to be modified on the side skirts to get them to fit? im about to replace mine and i would love a different look...
could you do a write up?
+1......
Not much to write about really, I will mention that the 2010+ skirts do protrude a bit outwards or inward which ever way you want to look at it towards the front fender area. There's this particular section that need to be cut off in order for the skirt line up to the body of the car. Other than that they just snap on with ease.
Looks good......on a side note.....someone on another forum asked if the 2013 front end conversion would bolt up to a 05-09. I say no,what do y'all think since the new skirts fit on the 05-09?
No. I mean, no different than what's needed to run the '10-12 stuff on an '05-09. The fenders don't line up. I'm sure it'll all bolt up for the most part, but none of it lines up.
Like 19cobra93 mentioned, the body panels don't line up. The fenders lines on the 2010 wont match the doors panel lines of the 05.
However I do suspect that the hood might possibly work on the 05+ but haven't come across anybody willing to be the Ginny pig for the retrofit.
The whole interior should swap out including the cluster (2010 only I think) you'll needs a 2010 e brake to make it work minus the door panel which won't work.
Personally the only things I like about the 2010's in the hips and hood's power dome other than that, I'm pretty pleased with my car.
