19COBRA93
Ford Racing
Price hasn't gone up, but pads are still on back order.
For the front you'll need the calipers, pads, pad hardware, and the rotors. You have to use the 15" rotors with these new calipers.So what would I need to order to do an upgrade on my shelbys front brembos? Do I just need calipers or more?
Whats up with the rear? The 13's should bolt on right but the lateral movement creates the problems?
Front calipers and rotors must be used together.I think you can bolt the 6 pistons right on, but why not upgrade to a 15 inch rotor also. The rear has a 13 inch rotor and much bigger single piston.
Because the rear brakes aren't all that different. larger rotors are about all you're gaining.15" is in the works already but I really dont want just front brakes upgraded. I want all 4. No one is stating much about the rear 13 brakes
That's what I'm showing, but I think the pads I have ordered have already been shipped. I should see them in the next day or two I'm hoping.Any update???? I heard pads are off back order on 9/27/12?
Bought the calipers, are there any 2 piece 15" rotors available? I would imagine the weight savings would be significant. How about brake biasing issues? Is the master cylinder on the 2013 gt500 the same as the 05-13 mustangs?
Any other wheel updates other than the ones already mentioned that will clear these brakes?
Ford Racing will be offering a two piece rotor for these brakes. They should hit the website any day now. That should shed well over 10lbs per corner. The 05-12 master/booster will work fine for any street use and most/some track events.
Any 19" or bigger wheel that fits an 07-12 GT500 will clear these brakes.
Will these work w/ stock gt brembo wheels? What about 18" custom offset forgeline wheels that fit a 12 shelby?
So 18s are out? I'd probably pony up the extra cash for the Willwood kit then so I don't have to run heavier wheels with a worse (and more expensive) tire selection.
Yes these will absolutely clear the 19" "Brembo" GT wheels. I have personally trial fitted them.Will these work w/ stock gt brembo wheels? What about 18" custom offset forgeline wheels that fit a 12 shelby?
so has anyone done this and completed it yet? pics? what are all the parts needed? would you do it again?
There might be a couple 18's that work, but the only one I know of is the Team Dynamics 18x9 and 18x10. I've personally trial fitted these and they clear. I don't know of any other 18's that will fit. Most will not.
Yes these will absolutely clear the 19" "Brembo" GT wheels. I have personally trial fitted.
Calipers just arrived, holy mackeral these things are massive! 13lbs each - pads and hardware on my bathroom.scale. Now I need to find a replacement for my heavy 20" Saleen wagon wheels. Thoughts on the TSW Nurburings,they are 20 forged and have a 40mm offset, think they would clear?
http://www.discounttiredirect.com/d...e.do?pc=65873&tmn=Nurburgring&typ=Car/Minivan
