Here is the pull to 18psi. Max IAT was around 76 degrees as well.
Motor is boss block, stroker, 9.3:1 compression. Mild ported heads, turbo cams, stock intake manifold, stock throttle body. That motor is built to rev, with an intake manifold to support some revs to 7200-7400rpms he's looking at 900rwhp easy on pump 93. That's thing is wicked. He is driving it around with the boost controller disconnected now and at 10-11psi spring pressure he says it rips!
Damn bobby looks badass I should do a Ty setup instead lol. And on 93 u made that much?may e I should stick with 93 instead of e85! But pump are already at fore.
