8.8 rear end swap
Discussion in '2005+ Ford Mustang v6 4.0L Tech' started by Sparsh0, Sep 4, 2017.
  1. Sparsh0
    Sparsh0 Junior Member
    19
    Aug 27, 2017
    Seattle, WA
    I have an '08 v6 and I was wondering if the 8.8 rear end is a direct bolt on ( minus the flange for the driveshaft) for the v6 or are the mounting points different?
  2. Wes06
    Wes06 forum member
    5,205
    Jan 21, 2012
    All s197 body's are the same. They use the 3 link mounting points
  3. oldVOR
    oldVOR forum member
    863
    Apr 9, 2015
    Northern Virginia
    As Wes06 indicated, it's a direct bolt up and the only thing you'll need if the trans and DS are still the V6 base is a pinion flange (M-4851-B) to adapt the DS.
  4. Sparsh0
    19
    Aug 27, 2017
    Seattle, WA
    Awesome! That's what I thought but just wanted to confirm. Any ideas where I could get the whole unit? Specifically with some bigger gears?
  5. Wes06
    Wes06 forum member
    5,205
    Jan 21, 2012
    Look in junkyards. Hopefully get lucky with the right gears you want. Otherwise you'll pay as much to swap gears as you probably did for the junkyard axle
  6. dre256
    dre256 forum member
    515
    May 8, 2012
    NJ
    Like mentioned all 2005 8.8 will work.
    But you can not use a 8.8 from 2004 and back. The new edge/SN95 and fox bodies used a 4 link suspension that isn't compatible with the S197s. But all the gears in the differential are the same 1986-2014
  7. oldVOR
    oldVOR forum member
    863
    Apr 9, 2015
    Northern Virginia
    Check CraigsList or Ebay and you might find a deal. The forums may turn up something as well. You may have to wait for the ideal setup or get the axle assembly and do gearing later.
  8. Juice
    Juice forum member
    163
    Aug 24, 2017
    I paid close to a grand for my 8.8 on fleebay. But I got springs, shocks,brakes, ebrake cables, and control arms with it. 05-13 will work.
    The stock GT lower control arms are actually lighter than the V6.
  9. dre256
    dre256 forum member
    515
    May 8, 2012
    NJ
    On eBay store I buy mustang stuff from and never had an issue is seller:midwaymustangparts they have full rears ready to drop in including suspension ranging from 450-800. Depending on gears, miles, differntial cover etc
  10. Juice
    Juice forum member
    163
    Aug 24, 2017
    Shipping on mine was $150. I picked it up at the shipping co. and saved $75 for residential delivery.
  11. Speedboosted
    Speedboosted Found missing cylinders
    898
    Oct 24, 2014
    PNW
    I've bought a few complete 8.8 rear ends for S197's, ranging in price anywhere from $120 to $400. All about finding the right guy. The $120 one was in great shape and still in my car going strong.
  12. Sparsh0
    19
    Aug 27, 2017
    Seattle, WA
    If I were to try and pull one out at a junkyard, would it have to come from a gt or could I get one of the explorer or ranger rear ends?
  13. JimC
    JimC Senior Member
    1,607
    May 5, 2007
    It has to come from a Mustang - the Explorer and Ranger rear ends have leaf springs for mounting and not the Mustang 3 link; plus the Explorer is a different width.
    You can use a rear end from any Mustang 2011 to 2014 and any GT rear end 2005 to 2010. Some of the 2011-2014 rear ends will have the correct flange on them for your V6 - won't know until you pull the rear end and check. I never figured out what the combination of options is that has some with the correct flange.
  14. Sparsh0
    19
    Aug 27, 2017
    Seattle, WA
    thanks for the info! very helpful.
  15. warpony4.0
    warpony4.0 Junior Member
    12
    Aug 8, 2016
    Thanks for that info I was wondering the same thing I had bought 8.8 3.75 I have a 08 v6 mustang so mine is stock with 7.5 just sucks now I know I am going to replace threat with 8.8 from a mustang GT so I can run 8.8 4.10
    Sent from my LGLS775 using Tapatalk
Share This Page
