All Motor Chat - High Gearing, Light weight, Revin to the moon-
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
I have 1 7/8 stainless works on mine with cobra jet intake cobra jet cams etc I figure in the 5-8k rpm range I will be in the 1 7/8 will loose little to nothing if not gain a little at 7-8k rpm
Sent from my iPhone 5S
ford20
White Plains,NY
Well 1 3/4 is bigger than 1 5/8. I think you mean 1 7/8. The Pypes design is stepped and should be good across the board.
Shit ... My bad, I did mean 1 3/4 or the 1 7/8ths.
I assume that I might pick up some power up top with the 1 7/8ths but loose some torque but a lot of threads on SVTP are saying that the 1 3/4 are the optimal size for a N/A engine but is that just for cars with bolt-ons?
That was my thoughts on it as well but people are saying that 1 7/8ths would be way to big for a N/A engine.
wbt
^^^ Has you covered across the board. Proper primary tube placement, stepped, great fit. :highfive:
Terry should be able to get you a good price on them (Pypes).
Matt D
S197 Pilot
Toronto,Canada
On another note I have found the light weight mufflers I have been looking for.
Vibrant weighing in at 1.7lb's each.
TheBlackPearl
Savannah, GA
So, back to the subject of cams. If got comp to grind me a set of 127300's with a 113 degree LCA and a 102 degree ICL, do you think it would perform similarly to the 127500's? This would allow me to retain VCT. I like the lower lift numbers for valve train stability/wear.
Here's the spec sheets for the two cams:
300's
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=976&sb=2
500's
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=980&sb=0
Tentative motor specs:
Diamond Flat Top Pistons (11:1 CR)
Ported Heads
FRPP Intake
JLT 110mm
Kooks 1 5/8 LT's
Good Rotating Assy.
Rev'd out to 7500 ish
Also, what do you guys think of these brakes?
http://shop.aerospacecomponents.com/4pistonfrontprostreetkit05-06mustang.aspx
ford20
White Plains,NY
Has anyone heard of any other N/A mods you can do to these Coyote's?
Currently I have:
  • RGR Stage 2 heads
  • RGR Custom Grind Cams
  • Ported CJ Intake Manifold
  • Super Cobra Jet Monoblade Throttle Body
  • JLT Cobra Jet CAI
  • Kooks 1 7/8ths Long Tube Headers
  • Kooks Green Cats for emissions - I know I could get more with O/R pipe, but I still need to meet emissions
  • JPC 2 3/4 Over Axle Pipes
  • JPC Alternator Pulley
  • Innovators West Balancer - Slightly lighter than the ATI Balancer
  • DSS Carbon Fiber Driveshaft
Outside of the Electric Water Pump, does anyone know of anything else in terms of N/A mods for the 5.0?
Scott
King City, Ontario, Canada
Currently I have:
  • RGR Stage 2 heads
  • JLT Cobra Jet CAI
Have you considered AC delete?
TheBlackPearl
Savannah, GA
Also if the chassis is a 2011+ you could swap out your steering rack for a flaming river manual rack. Not a power mod but lightens up the car a bit.
ford20
White Plains,NY
I have thought about it, but I didn't want to go that far right now as I would still drive the car quite regularly on the road during the summer. I was also thinking of doing the wiper fluid delete since I don't tend to use it that often and it will save some weight.
I doubt, I would do the manual rack as it will more of an open track car/autocross car and then eventually move into AIX once my skills develop even more.
TheBlackPearl
Savannah, GA
Swap the heads out for 2016 heads. They have better valve train geometry, can handle a more aggressive camshaft at sustained high rpm.
ford20
White Plains,NY
Those are the 2015+ heads and I'm not swapping out $4,000 machined heads for the GT350 ones haha. They should flow about as well as the GT350 heads and with the larger valves and a little bowl work should work pretty well.
06 3v
portsmouth ohio
Sorry to bring a old thread back to life but I was wondering if I can run 4.56 rear gear with 100shot and full bolt ons with a 28inch tire
46addict
13726548
Lawrenceville, GA
For a track focused car gearing should be based around trap speed and avoiding a shift just before the stripe. With a 4.56 expect 6500+rpm at 120mph on 28" tires.
tjm73
of Omicron Persei 8
Rush, NY
Off topic but what happened to US-1? (sd wheeler?)
He is/was a scammer that screwed a few people here and if you google him that is/was his MO on other boards as well. We ran him off.
