sportinawoody is sportinablown motor is sportin a new build thread
sportinawoody
Piedmont area , N.C.
got the motor all spec'd ,assembled sat in the car and bolted downafter work this week. chomping at the bit now but lost an exhaust bolt, exhaust gasket and missing the ect harness so it looks like another delay. will put up a few pics tommorrow
crownaviation
http://www.tudyno.com/
Broke dafuk down
We all know drywall screws can ruin your day... I would not want to see an exhaust bolt go thru the motor for sure!! find everything...
sportinawoody
I meant misplaced when I disassembled the motor but I found it now. Jim, I'm waiting on the guy to get me the jesels and once they arrive, we'll go from there
sportinawoody
naw, my motor is together, I'm tapped from this build because all the supporting stuff that I upgraded along with all the engine stuff just took its toll on my wallet. the jesels are going up when they get here. fixing to start pic whoring
sportinawoody
this is where I started Monday night and where I left off today waiting for some odd and end stuff . enjoy
oliver makes some good stuff
unshrouded intake valves per yours truly
BruceH
BBB Big Bore Boss 322
Looking good. Be sure to check the front cover for fitment on the 1L block. You don't want any leaks I'm sure.
When does it start?
sportinawoody
probably Thursday night is what i'm shooting for due to waiting for mail order parts, injectors, etc,,, where are these blocks prone to leak from the cover.
sportinawoody
just in case its not known, the ford head gaskets and arp studs don't play nice together unless you do 10 lb increments when torquing. if you double check your torque then that ads up to 4000 clicks of the wrench. took me over an hour to torque these things.
go302
Tits McGee
Oklahoma City
^^ I did 33, 66, and 100 using the frpp head gaskets and arp studs a few days ago. What problems did you notice?
sportinawoody
i haven't noticed a problem, haven't started my engine yet, but my machinist has built tons of 2,3,and 4'vs and clued me in on a few trade secrets with the building processes of these engines and he has seen issues arising from torqueing an mls style head gasket with the increased clamp load of the arp studs. something along the lines of crushing the gasket instead of clamping it or something or another. anyhow he states it is a pain in the ass but he has yet to see the mls fail with this torque sequence when using studs, so I took his advise.
Department Of Boost
Alpha Geek
So what's the sequence?
