sportinawoody
Wouldn't you know the same day I got the title in the mail, I had the usual broken rod syndrome causing air conditioning of the block. Anyhow, I was on a stock engine at 69k with full exhaust with L/T's, comp 127300's with springs, whipple at 11 psi and 10 rib, and 62mm bbk t/b all for 30k or so. My fault really as I turned this motor 6500 when told not to from day 1 for 2 years and for the last year or so I got burnout happy just showing my ass. Build is getting closer to completion finally so here's what's going on.
04 mach1 aluminum block
3.750" stroke Kellogg crank
oliver 5.850" rods
diamond 17cc pistons
totalseal ap rings with stainless top ring
clevite bearings
all arp short main studs, head studs, side bolts, crank bolt flywheel bolts
all the machining to complement including line boring, torque plate honing and filing rings with torque plates bolted down,threading oil galleys, but just surfaced block and not zeroing the deck
gt500 pump with TSS gears
13-14 gt500 8.5 quart pan with scraper/gasket and pick up
new frpp timing set
new frpp lash adjuster and rocker set
unshrouded intake valves courtesy of my own skills
Viton valve stem seals
checked spring pressures on comp 26113 springs-all checked perfect
3 angle valve job, refaced valves and replaced some bent valves
comp limiters
keeping the 127300's as the driveability is awesome unless I find some 350's cheap
ditching the bbk 62mm in favor of hopefully finding an l&m 62mm
ID1000's injectors
sent the whipple to whipple and had blower inspected and rebuilt along with 10 rib snout which received updated parts. Currently back in route to my house
18lb lower pulley for 10 rib
jpc elbow along with 5" maf housing and tube and vmp maf meter.
think I'm going to keep the whipple elbow and just run the bigger tube and maf housing and see what happens.
also using my custom 2 3/4 gallon hidden H/E tank that mounts behind the fender and going to enlarge the hoses and fittings to the blower intercooler
also, debating 100-150 shot for the limited track days it will see.
Other small stuff is motor mounts, clutch, bulk of frpp oil filters, fluids etc..
I know some will think this is a little overkill for the little jr. 2.3 TS but my plan is to heal my raped wallet for a year, get the heads ported next winter, bigger better valves, sell the whipple and cams, go turbo and give this engine what it craves. I have an issue to deal with regarding my oliver rods with oliver and then the assembly will start as all the parts are bought and sitting on my build table. Don't ask how much $$$, I haven't tallied yet but those that have ventured this road have an excellent idea of how much $$$ and for those planning to do this, my best piece of advice,,, set a spending limit in advance and don't " wing it ". You will blow thru soooo much money soooo fast it will make your head spin and may make some wind up in divorce court LOL ! I may ad pictures later as I find time
oliver 5.850" rods
clevite bearings
new frpp timing set
comp limiters
ID1000's injectors
