Like a 3v with 8 lbs of boost I sure.
I wouldn't say that. Less boost yes, what I've seen is that most people forget 11-14 have way better geared transmission who play a huge role, yes the engine is way better but mating the engine with a 3650 like Dylan did will be different, he won't be able to match a bolt-on 11-14 with an MT-82, both well driven.
People focuses on engines and forget transmissions.
Run Type R badges.
With V-Tech right under it.
Quite amazing dude....well done.
I like the Mustang badges better also!
Where are you planning on running the Evap canister? If you mount it under the car in the same spot would the water from the rain have any effect on it?
Thanks Pat!
Yeah, I was going to put the tank in the OEM spot with the OEM shield around it. I don't see it being a problem unless I drive the car into a couple feet of standing water. If that happens, I will probably have worse things to worry about than $5 worth of carbon lol.
Badges went on the other day. So weird seeing a 3V car with 5.0 badges. A co-workers GF met him at work for lunch today and she was really baffled by the Coyote badges on the car lol.
Looks good imo.
Definitely does, but it's still weird to see.
As I was leaving school yesterday I saw some kid look at the car, make a weird face, then start glaring at me. I think he knows the badge doesn't belong lol. I need to get a louder exhaust so they can hear the 4V.
That's the fun of different but correct badges.
