DKS
Wax on, Wax off.
If any of the Meguiars waxes are leaving swirls or scratches than you're doing something wrong or the product is bad more than likely from heat and moisture. I've never had that problem and I've used all of Meguiars products.
Agreed 100%.
Greg, are your pads contaminated or something? Has to be a variable there if you're getting swirling from these products.
NXT will cause some streaking if you put it on too thick, don't shake it well, or don't remove it correctly since it has a lot of oils in it, but it's not going to swirl the car. There is a technique to removing sealants that is slightly different than waxes.
