BMR Watts Link - Teaser
BMR Tech
Traction Vendor
Official Vendor
Tampa, FL
Seems like this kit is three life times away from hitting the market.
Well, keep in mind....we developed several styles.
We went through about 5 diff mount designs, before narrowing it down to 2 now....
We made 3 different Chassis Mount designs, and we chose this on I pictured above for various reasons.
It is easy to build and sell a part. It isn't as easy, when you build and sell a part that has to meet many requirements, in an effort to push the part to the top of the market (share). :beerdrink:
one eyed willy
Pizzle fo shizzle
Lakeland FL
If you want to test one out on a air ride car......let me know.
Wes06
Nope sorry. I threw my hat in first. I'll be the first with it on air to test :)
one eyed willy
Pizzle fo shizzle
Lakeland FL
but I'm only 15 minutes away......and been bugging Kelly about it for probably over a year now! I will make the sacrifice to help all my fellow air ride brothers, you can thank me later!
KingofQueens
Queens, NY
its ok, u all get one!!!
BMR Tech
Traction Vendor
Official Vendor
Tampa, FL
$549.95
Just about all of my hair has fallen out, getting it there.....
You are welcome...
Whiskey11
SCCA Autoscrosser #23 STU
$550! Count me in if it fits verts
There is no reason it couldn't work with a vert....
If you take the vert braces off...
As for making it work with the vert braces... you'll have to ask Kelly if you need to remove them or if you can use some of the other mounting points to accomplish the goal.
The best solution to the vert problem is to not buy a vert in the first place... but what do I know! :)
NickD87
Toronto, Canada
WOOO
So 550 for the chassis mount version, prob cant do much less for a diff mounted version,
are you going to still produce two models.
If you skip the other you could spend more time on the axle brace :highfive:
BMR Tech
Traction Vendor
Official Vendor
Tampa, FL
I think the diff mount version will be less.....only time will tell. :)
No ETA on the axle brace at this time.
BMR Tech
Traction Vendor
Official Vendor
Tampa, FL
This WL005 / WL006 (yes, part #'s are official) - is every bit of a $699 - $750 Watts Set-Up....
I will tell you, for a fact, we will be raising the pricing down the road on this piece. We may stagger the pricing, or just raise it all in one shot for 2016....not sure at this point.
That said, we truly price our components on formulas....(this is why our rear sway bar is $420...if you don't believe me) - so, the less it cost to build it, the less our price is.
If this thing sells like we think it will, the pricing may not end up as high as I anticipate 1-2 years down the road.
The diff mount, is the version we planned on shaking the earth with the pricing. That unit, when it gets released....should be that piece that is the $450-$550 Watts.
