AndrewG27
I do have the boss manifold.Unless you have a boss manifold there is no point in revving past 7.
The results on our car speak for themselves.
11.12@122mph is our best time so far. The car has gone a best of 123mph. Here is the short list of mods.
Dynatech LT's, no cat mids
Pypese 3 inch supersystem
Boss intake
JLT CAI
Mcleod RST clutch
Metco LCA's with relocation brackets
Alum one piece DS
Stock 3:73 gears with true trac diff
Stock shock, springs, struts.
Racestar 15x10's on the rear with 28x10.5x15
Racestar 17x4's
Race weight of 3550 with driver.
Tq reduction was on in those runs and we are shooting for better times soon.
JJ
Was this with pump gas or tuned for race gas?
i beg to differ, you typically want to shift 200-300 past when your power starts dropping off
that is why i am trying to keep a 7700 or so shift point
plus it brings you in at a higher rpm and better power range on the shift
Exactly. stock manifold drops off around 6500. so turning past 7k is pointless.
What i meant was if you are stock stay under 7k Unless u have a boss mainifold.
Do any of you see a point of running the Boss intake if you are not launching around 6K?
The graph has nothing to do with what i said.
My original comment was "Unless you have a boss manifold there is no point in revving past 7."
He responded with "i beg to differ, you typically want to shift 200-300 past when your power starts dropping off
plus it brings you in at a higher rpm and better power range on the shift"
And i was agreeing. he is running a boss, so his power carries past 7. a stock manifold car will drop off at or around 6500. So my original statement of not going past 7k UNLESS u have a boss holds true.
Sorry if i wasnt more clear.
I don't think Beefcake is running the Boss intake, I could be mistaken though.
i dont think i agree with this for this reason: 3 mph.And i was agreeing. he is running a boss, so his power carries past 7. a stock manifold car will drop off at or around 6500. So my original statement of not going past 7k UNLESS u have a boss holds true.
i understand. im grannyshifting and running in shitty air, so my times are not what they should be. i am aware of this.I ran 113 bone stock shifting at 6600. and a 116mph shifting at 7 with just a tune...
all im saying is, i raised my shift point and the car picked up by 3 mph. i think thats pretty significant considering "hp drops off after 7k". if that was truly the case my mph would've went down.
Isn't that the mantra of JPC? lololShift high!!!!!
