don_w
Dyno Numbers - Who Cares?
This is particualrly handy for those of you with a cage, and who use a harness at the track instead of the factory seatbelts. In my case, it seemed like the seat belt alarm beeper would always go on just as I was trying to concentrate staging the car.
The following procedure sounds strange, but it worked for me.
1) Car off, all belts unbuckled, parking brake on
2) Turn key to on position. you will see seat belt warning light light up red
3) After 1 min, light will go off, now you must buckle and then unbuckle seatbelt you want to disable warning for 9 times exactly and finish doing this within 50 seconds of the light going off
4) Airbag light will go on for 3 seconds or so
5) After it goes off, buckle then unbuckle seatbelt again 1 time
6) Light will flash, seatbelt warning disabled.
