luv2cheat
I would like to remove my Driver side airbag in an effort to shed a few more lbs. Has anyone seen some type of cover to replace the airbag that looks decent. I would like to keep the OE steering wheel for now.
do you drive this car on the street?
is yes, is saving a few pounds worth risking injury or life?
Very limited street. I have already removed the passenger side airbag. So the driver side is useless anyway.
I'm curious as to how the driver's side is useless now. Don't the two bags act independently of one another?
I dunno, if you're driving it on the street at all, it seems beneficial to have a bag. Wanna shed those 2lbs? Take a man-shit before you make your pass.
If you're any good with sheet metal I no way you can do it.
I'll see if I can get you a picture tonight I made a sheet metal bracket to hold the front plastic pc off the airbag. Then I filled it with spray foam to make it hard again.
I didn't think it was exactly legal to remove safety equipment from a public road faring vehicle?
it's not and if there is a safety inspection required by the state the car could certainly be failed by a diligent inspector.
Its also illegal to cut out your cats, and numerous other things....
