luillo
I got Long tubes installed, Jlt CAI and Boss also with BBR Tune 91 octane.
The car ran fine until today right after i did a quick 3-4 gear power shift test with the engine rev from 4,000 to 6,000..
The problem is that on a stop light i let the clutch pedal go a little bit and press the gas pedal and the engine start hopping and then stops when is on its way.
At first i thought it was something wih the tune because when i stop at a light the rpm goes down and then back up, but i keep hearing that the computer needs to relearn and also after that the car is stable at 900-1,000 rpm.
Now i think is the clutch not having enough pressure or just worn out. I have a new clutch awating install on monday but i wanted to know if anybody had a problem of these nature and end up been the clutch.
