FRONT CRANK SEAL R & R
EGAZ
I need some pointers in replacing my Front Crank Seal in my 2006 4.6L. I understand that the radiator fan and reservoir need to be removed as well as the pulley and harmonic balancer. Are there any tidbits of information regarding the pulley removal? I will be working on my back on my garage floor in 100 degree heat (I live in the Phoenix area). Any tips for a quick R & R job will be greatly appreciated. Thanks.
07 Boss
Sin City
I believe when I pulled my front cover I used the starter to undo the crank bolt. Place the ratchet or breaker bar against the ground and blipped the starter to loosen the bolt.
Hollowdweller
Not as brave as 07Boss but that sounds fun!! I rented the tool from Oriellys to do it….easy to use, only took a few mins to do
mattjames
I've done it with taking the front cover off, some say its not necessary but it's what I was comfortable with
MasterofDisaster
Michigan
When I installed underdrive pulleys, the AutoZone special tool wouldn't work. The Blue Point tool worked great, and I didn't have to remove the radiator.
I think I left the car in gear, parking brake on, and used a breaker bar to remove the crank bolt.
