US-1
Banned
Ok......here is what I'm going to add to the kit.
1. GT500 pump kit
2. 39# injectors
3. MAFia
Anything else?
1. GT500 pump kit
2. 39# injectors
3. MAFia
Anything else?
No more than 500 rwhp.
I would have the MAFIA ready just in case, I would also get the 60 pound injectors also...............you know how this is........
US-1 said:Here's the deal. Sponsor tuned their initial kit (twin 54mm turbos) with a stock fuel pump and 39# injectors. They made 450 hp/460 tq. This was on a five speed setup with 8 psi. I'm figuring with my automatic anywhere between their numbers and 500 rwhp. So with that in mind.....do I need more than the 39's and is the MAFia necessary?
I could see having the mafia just incase, but the 60's really arent needed. PLus the idle/part throttle with 60's i hear is a bitch to tune and to get it to idle smooth. If you dont have self control and know you will turn up the boost, get both. If your like me and know your limits - you will be fine with the 39 injectors with no Mafia.
Actaully this saturday i am going to the dyno for a 9psi tune. I should be close to 470-480ish at the rear, i will let you know how the MAF voltages and injecotrs cycles look.
well they were using the STOCK fuel pumps. I can guess they ran out of pump well before running out of injectors. With an automatic, you will probably have to run close to 10+ psi to hit 500 - at this point you take a chance at blowing your engine. If you dont care about the engine and plan to go higher after it blows, then hell yes, get the 60's and mafia now so you will have them after you rebuil the motor. Keep in mind, 500 on an auto is about 530 with a 5spd.
actually, now that you say you have an auto, you will probably need the mafia and 60's. If you were a manual, id say you could probably get by without. SO if your dead set on the 500 mark (and willing to take the risk of blowing the motor), they yes, you will probably need both.
Ok....thanks for all the help. After reading these posts and consulting with Richard at Strictly, we're going to do the GT500 pump setup, 39# injectors, and we will have a MAFia on hand just in case.
This is a great site.
