I need a pinion flange for the diff,Ford will not sell any part of the GT 500 rearend,if you break a axle,you must buy the entire rearend assembly etc.New rearend $ 3,000.00 what a joke.Be careful with your rearend!Can anyone help me on this one????
They really should be the same as the GT part - I have a Powerhouse driveshaft for a GT500 to go between my GT rear and my GT500 transmission... Fits just fine (the PH uses an adapter that goes into the flange like others on the market).
So far as I know the entire rear-end assembly is the same...
As for being careful with your rear-end - well I think that should go without saying...
But more importantly and all jokes aside with these cars as they are heavy and when you add torque to a heavy car, your rear-end and trans pay the price...
Here's some ASCII art of my 8.8
BEFORE:
[]--O--[]
AFTER:
[]~~X--[]
And how... Have a 9" ready to go on the garage floor, but I did not want to cut 2 custom driveshafts so its waiting for the "big-bad" transmission from promotion that I had planned to do later this year, but bending up the 8.8 changed my plans a bit...your asCII rear end looks liek it got
In the mean time I cobbled some parts together to keep the car moving and changed clutches to prevent twisting up the stock rear - works fine but howls like hell over 50MPH... (gears got scored when the carrier/axle bent but were otherwise undamaged - so I threw them back on the stock carrier)...
Fun, fun, fun! (actually I have had a lot of fun - I just wish I had some times to show for this work, but I needed to get back up to speed anyway both with the wrench and the feet)...
Well, again since the GT500 and GT share the same rear, you just need a GT flange unless I am missing something...I need a pinion flange for the GT 500!!!!!!!!!!!!
It is my understanding that the shaft differrs:The GT 500 driveshaft & pinion flange is different than the Mustang GT 05-07.The rear ends are the same.
I am ready and willing to believe, but let me explain in detail why I don't yet:The GT 500 driveshaft & pinion flange are not the same as the 05-07 Mustang GT,the rear ends are the same,but not the pinion flange.I need a pinion flange for the GT 500!!!!!!!!!!!!!!!!!!
