Jan 16, 2009 #21 Freaknazty KEYBOARD NINJA S197 Team Member Joined Jan 18, 2008 Posts 5,786 Reaction score 56 Location SOUTH LOUISIANA hey mike what is the length difference between the 2 ?
Jan 16, 2009 #22 M Mike@PowerHouse Member Joined Apr 9, 2007 Posts 369 Reaction score 2 I do not remember exactly but I think it was 5/8 to 3/4 of an inch difference. It is only a bit.
Jan 16, 2009 #23 Eric298 Got V8? Joined Nov 1, 2008 Posts 212 Reaction score 0 Location Virginia weird a few members on here claim that they used their aftermarket driveshaft that was for their 3650 on their new 6060 with no problems. Stretchable driveshafts? lol
Jan 16, 2009 #24 cekim Large Member S197 Team Member Joined Apr 6, 2007 Posts 6,445 Reaction score 38 Location Earth Eric298 said: Stretchable driveshafts? lol Click to expand... Actually, yes - they have slip joint witha fixed flange instead of slipping on the shaft as the older transmissions did... the CV boot they put over this joint acts like a spring pulling the flange back on to the shaft... So, in a sense, yes, they are stretch/collapsible... The issue is whether you either: a. compress too far (bind) in one configuration OR b. stretch too far (leaving too little spline engaged) Frankly at 3/4" difference, it might not be either, so that would explain why it works, but best to double check...
Jan 16, 2009 #25 M Mike@PowerHouse Member Joined Apr 9, 2007 Posts 369 Reaction score 2 Exactly what he said. It may work, but I cannot guarantee the shaft if not used for the original application. But there SHOULD be enough travel to do it.
Jun 27, 2011 #26 B Boomer_Gooner forum member Joined Mar 23, 2011 Posts 175 Reaction score 0 Location I is a Texan So what is the exact length of the stock GT500 driveshaft?
