i did search and didnt find a thread on this but lets see what gauges your using and which sos pod you use
Whyask what dash Do you have? Also lightblade where did you get you dash kit? Any one have night pictures with there gauges lit up?
Only complaint I have about the SOS is that mine has an obnoxious buzzing rattle. I'm sure it's fixable just haven't been real driven to mess with it since the car sits in a 20 degree unheated garage atm.
Given the choice again, I would opt for the dash mounted gauges. The gauges tend to block your view and are a bit too close to read easily. In addition, My SOS pillar pod will not stop rattling. Then there is the fact that one pod won't hold the gauge tight enough and the next pod is too tight to remove the gauge. Honestly, I've spend hours fussing with it and it still isn't quite right. Moreover, it is a stock A-pillar with 3 plastic gauge housings riveted on. There is no reason you couldn't make one identical for $10 bucks using your existing a pillar.
waldog, awsome setup. love the CF, parchment, and black door inserts....
tigerhonaker
My personal favorite is probably the charcoal dual pillar with a Nexus setup. So clean looking to me, but it's a costly choice. Seems like I never like anything cheap, dammit! The same setup in a triple looks great, but the dual has always been my personal preference.
Thanks for the link. I may look into it next year when I feel like working the problem. There are mulitple possible causes.
I can only say a few things with certainty at this point. The rattle was not there before the gauge pod went in. It is not the gauge bezels or the pods themselves doing the rattling. I can push against the trim portion of the pod even along the top and if I apply pressure the noise goes away. It isn't obviously coming from the bottom which is where that TSB tends to imply the problem would be.
SOS pm sent
you can't buy that kind of service...
Why didn't you make JUST ONE attempt to remedy the situation with us? That's all it would have taken.
