Mastering the art of the S197 3 link suspension (sixty foot)
429244
Speaking of launch...
Thanks for keeping us posted on your progress.
That track must have a good photographer. He is getting great pictures of your car.
fdjizm
Drag Queen
NY/NJ
Dude putting in work, love it man!! I can't wait to get to the track and fuck around with my shocks... 7+ on the rear that's hard as hell no? guess it works though!
lindertw
NoVA
thanks! just saw your update - hopefully you can hit the track when it's prepped to see your progress!
+7 didn't feel too bad at the track, but I failed to put it back for the drive home. 80+ miles on that setting was a bit much, my back is sore this morning.
looking forward to your update(s) - get to the track dammit!
uca upper
lca middle
14-15psi cold in your QTP's
+6/+7 on your strange shocks
full loose on the strut
launch @ 6500-6800 (can't remember what your limiter is set at)
hit that 11.9999999
fdjizm
Drag Queen
NY/NJ
uca upper
lca middle
hit that 11.9999999
Thanks homie!, I have a rental at etown the 24th of oct. soooooon!
I really hope my QTP's are not dry or some shit they are pretty new, possibly over heated but don't think that would kill them.
why can't my car hook like yours! :thud:
1.63 is killing it :beerchug2:
lindertw
NoVA
went to test and tune at my local 1/8th mile track last night. Prep was non-existent, but I wanted to get a feel for the car with the ps delete belt installed before I head to MIR for midnight madness tonight
weight unk (prev 3570 lbs with full interior and 1/4 tank of gas)
pass seat and rear seat bottom/backs removed, 1/8 tank of gas
ps delete belt
front strut full loose
rear shock +7 clicks from full soft
15psi cold in rear tire
6500 rpm launch off limiter
prev best 60' 1.638, prev best 1/8 was 7.899 - I'm chipping away at it:
Kelly, I didn't make any shock/strut changes since the track prep was bad - I would've been just chasing my tail (add to that there were LOTS of cars on street tires going right through the water box and leaving the line wet).
Air and prep at MIR tonight should be great, so hopefully I can make adjustments and get my numbers to drop more. A 12.teen run is my goal, can't wait to hit the track...
Fabman
Children Of The Corn
Pleasanton, Ca.
Just a tick off my best time of 10.22 but she's really hookin' good.... 1.4's all day.
lindertw
NoVA
*edited to include data in the correct format in addition to all my rambling below*
- Shocks - strange single adjustable
- Rear springs - cobra jet (m-5300-q)
- Struts - strange single adjustable
- Front springs - cobra jet (m-5300-q)
- Lower control arms - metco
- Relocation brackets - BMR
- Upper control arm - metco (with metco UCA mount)
- posi/diff - eaton truetrac
- Pan hard bar - competition engineering adjustable
- Pan hard bar support brace - competition engineering
- Gear size - frpp 4.10
- Brand/ tire size - M/T ET street (bias) 26X10.50-15
- Clutch or which converter at what stall? - OEM clutch
- Anti roll bar or which rear sway bar - OEM sway bar (no arb)
- 302 rwhp
- 3490 lbs race weight
pinion angle set to -2 deg
LCA set to middle hole on BMR relocation brackets
UCA set to uppermost hole on UCA mount
12.339 @ 108.86, best 60' of 1.611
test & tune / midnight madness at MIR last night (24OCT14): my times continue to trend down!
weight 3490 with driver/helmet, 1/8 tank of gas
ps delete belt
pb 60 = 1.611; 1/8 = 7.819; 1/4 = 12.339 DA was between +99 ft and -299 ft throughout my runs per drag times calculator
Spun bad on the third pass after following several street cars that drove through the water box
I missed 2nd gear on the last pass, it may have bested my 12.339... There's still some tweaking to do with tire pressure and shock/strut settings. I may have a high 1.5x 60' left in the car, and maybe 12.2x ET by years end.
Congratulations. It is good to see that you are still progressing.
06redgt
Oswego, Illinois
What is everybody using for motor/trans mounts? Still using the factory mounts or did you upgrade to something else?
Bud
Northern Colorado
Car has been 1.25 to the 60', wouldn't mind cutting a few more hundredths out.
- Shocks - Strange SA struts, QA1 SA rear shocks
- Rear springs - JPC/Eibach, these ones http://www.jpcracing.com/05-11-mustang-gt-gt500-rear-springs-only-pair/
- Front springs -2008 CJ
- Lower control arms - Custom set built by OKRC, heim joints
- Upper control arm - Racecraft UCA and mount
- posi - Spool
- Pan hard bar TRZ
- Pan hard bar support brace TRZ
- Gear size 3.50 (with a glide)
- Brand/ tire size MT 275 pro radial
- Clutch or which converter at what stall? PTC converter, launch around 3900
- Anti roll bar or which rear sway bar - TRZ Antiroll bar
Running the BMR K and control arms up front to drop weight up there. Car is very light, 3220 race weight. 51% front, 49% rear
Will have to do control arm measurements sometime this winter. Would really like to drop the 60' just a bit more without fear of the front end coming up, which so far it has been tame.
Bossmustang16
3v to 4v
Yadkinville NC
1.65 60 ft
2010 3v
full bolt ons 100 shot
ford racing k springs and upper arm and mount
3.73 gear
275/60/15 MT Radial Pro Launching around 4500-5000
kdanner
Austin
Just got some stuff that might interest you too. Not a one size fits all, they want hp and weight/weight distribution info so that they are valved appropriately. You can get titanium springs too if you're a baller. :naughty1:
These are stock eliminator legal, I think they have something different intended for super stockers where the stock spindle goes away and saves more weight, which could interest you more.
Bud
Northern Colorado
Looks very nice but way out of the current budget. As you can see from my current gear I'm having to do more with less. Someday I would like to move to coilovers and shocks that are valved for the weight as my car is way different than most s197's in that department. Would also be nice to be able to lower the car some, it sits pretty high currently. Guessing the front coilovers would weigh less than a strange strut and stock type spring setup.
The level the car is running at it probably could use some application specific suspension but unfortunately my budget might allow for viking DA's rears and that is about it.
DVEST8R
1.38 60 foot
-stock springs
-stock struts
-viking da rear shocks
-upr race lcas
-upr race upper arm
-bmr relo brackets(custom)
-che brace
-upr rad. support/swaybar delete
-bmr panhard relocation
-maximum motorsports spherical end panhard rod
-31 spline carbon clutch frpp trac lok
-circle d 3c stall
-frpp diff girdle
-bmr housing bushing
-no arb :(
-m/t 275 radial pro - 17.5 psi
Unreal
Gilbert, AZ
Finally all ready to go back out. Got the LCA brackets on (not without a bunch of swearing, hardware store runs, and beer). Put them in the middle hole just because that is the only hole I could somewhat get the LCA to line up, so I went with it. Was tired of fighting the LCAs to get on. Also test fit the 295 hoosiers and went around the block. They work well. Got to mess with the shifts to bring them up a bit with the 28s, but should be good. Hoping to see some 1.6s with the circle D 4c and these mods.
lindertw
NoVA
if you have to move them again do one side at a time, and use a ratchet strap to keep the axle from moving (one end around the axle, other end on the trans mount). much easier this way :beerdrink:
Unreal
Gilbert, AZ
I had to take the shock off, sway bar off, then lay on my back kicking the brake rotor as my wife tried to jam the bolt in. What a pain in the dick.
