Don't know the cost of the cluster, prolly not cheap though, I had a full donor car to scrap off of...
Yes, the main cluster makes the shape of an H Two top parts of the H go to up each side of the engine through the fire wall. The cross beam of the H would be what's hidden under the dash. Then the bottom two sides of the H go all the way back to the rear lights. In the middle of that harness is the harness plugs for the GT500 fuel pumps and what not.
Also there were some changes that needed to be changed on the harness. I don't know for sure if it's between years of cars or if it's between models. However, I did have to cut and solder in from my old harness:
1) Rear lights, brakes/blinkers
2) Rear Bumper lights
3) Both passenger and driver seatbelt wires
4) Clutch Neutral switch
Let me know if you have any other questions...
